-   -   Threaded Insert (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1155455-threaded-insert.html)
dennisv 01-30-2024 11:23 AM
Threaded Insert
Got our chain cases back from tumbling. Discovered that one of the studs was missing and the hole is not threaded. Is this a DIY job? Given this is magnesium, is it better to heli-coil, case saver, or time sert?
http://forums.pelicanparts.com/uploa...1706642503.jpg
mikedsilva 01-30-2024 11:30 AM
I think you'd be fine with a simply helicoil. Not much torque on these studs.
stownsen914 01-30-2024 02:46 PM
Strange it's not threaded. Sounds like someone goofed at some point. I'd agree a helicoil should be fine there, if you've got enough meat to work with. If the hold is too big, an oversized timesert or similar should take care of it.
john walker's workshop 01-30-2024 03:34 PM
Timesert. I don't care for helicoils in most apps, other than steel/cast iron. Even then, I prefer a solid insert.
