-   -   I can’t recall where this goes (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1155804-i-can-t-recall-where-goes.html)
porschedude996 02-04-2024 04:44 PM
Currently rebuilding engine. I plated a bunch of parts. I can’t recall this coming off my engine (3.0). Any ideas? 8mm nut for reference.
http://forums.pelicanparts.com/uploa...1707093789.jpg
porschedude996 02-04-2024 05:04 PM
I looks like it would go on the end of the crank pulley, it does nest in there, but the bolt is too short and there is no reason for it.
boyt911sc 02-04-2024 06:06 PM
Mystery Washer/s…………
There are two (2) of these washers in your motor! CLUE : Left side and right side.
http://forums.pelicanparts.com/uploa...1707098336.jpg
Tony
porschedude996 02-04-2024 08:30 PM
Thanks, I have a few parts to do with the valve train that I have yet to comb through. It’s mate should find its way to the surface.
PeteKz 02-04-2024 11:39 PM
Washers for cam bolts, if your cam has bolts instead of big nuts?
porschedude996 02-05-2024 12:12 PM
Petez, very late 1983, in fact it is a 3.2 case. Big bolts, not big nuts.
PeteKz 02-05-2024 05:26 PM
Do they fit the cam bolts? And cover the pin that goes into the timing sprockets? If so, there's your answer.
porschedude996 02-05-2024 07:04 PM
I only have the one engine. Not like your arsenal of engines pete. ;)
PeteKz 02-05-2024 11:51 PM
I do have a spare laying around...
porschedude996 02-08-2024 07:00 PM
Thank pete, I found it with the other bolt, sprocket s and followers that i’m changing out.
ryanrobert 02-08-2024 07:07 PM
I must have learnt alot from these thread , thanks buddy
porschedude996 02-08-2024 07:11 PM
Are you a troll?
