-   -   Engine mounted oil cooler question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1157751-engine-mounted-oil-cooler-question.html)
zztot 02-20-2024 06:25 AM
I see Sierra Madre is selling new engine mounted oil coolers ( aftermarket).
Does anyone have knowledge or experience with them.
gled49 02-20-2024 08:20 AM
I saw new aftermarket engine coolers at RennSport. They come with interchangeable inlet fittings for different applications. They moved away from the original drawn cup construction to tube and fin design. I suspect they are more robust and they looked pretty nice. Couldn’t find pictures, maybe someone else who saw them will comment.
PeteKz 02-20-2024 03:58 PM
The company making them started a thread in this forum about a month ago.
HaroldMHedge 02-20-2024 08:44 PM
CSF Engine Mount Oil Cooler
Thread Announcement - NEW CSF Porsche 911/930 Turbo Engine Oil Cooler
CSF Website
Pelican listing - Porsche CSF OEM+ Performance Engine Oil Cooler, 67-89 911/930
Personally, I would rather have the CSF one than an unknow manufacture from Sierra Madre.
Edit
The Sierra Madre oil coolers that I saw have welded connections for the thread/pipe nipple so it does not appear to be the CSF cooler.
911 tweaks 02-23-2024 01:05 PM
My recent experience with engine mounted oil cooler's is to buy the csf cooler.
I spent 1.5 months scrounging up used oil coolers on eBay, pelican etc only to have all 6 of them fail when being cleaned & tested.
Save yourself all the time & hassle and spend the $$ to get a new cooler…
Unless you like to roll the dice on a rebuild or whatever your reason is…
Henry Schmidt 02-23-2024 02:38 PM
Although I have no experience with the latest versions of aftermarket coolers, my experience is that they can't handle the vibrations associated with 911 air-cooled engines.
When we need a new one, we buy the factory original Behr cooler. They are still available and with all things considered, the cost is still reasonable.
911 tweaks 03-04-2024 02:33 AM
911 tweaks 03-04-2024 02:36 AM
Depending on cost may your reason on which to buy…
I decided to give CSF a try because it has a 10 year warranty and their video sites, improvement in functionality versus the Porsche OEM bear cooler… Time will tell…
