It's a 914 ...
Removing the pickup tube from early oil pump
Google wasn’t helpful on this. I need to (non-destructively) remove an early 930 oil pump pickup tube/screen from the oil pump. Just heat the joint with a propane torch and twist/pull?
That’s how I’d do it, maybe map gas.
