911 3.0 - Engine sound ?
We are rebuilding our 911 3.0 motor. (1979)
We are going to replace several rocker arms and the camshafts, these are damaged. The block is line drilled and there will be new bearings. It was an metallic screeching sound, increasing with revs. Same sound without fan belt, i.e. not from alternator or fan. What could this noise be coming from? Please, can anyone help us? :) Watch the video clip : https://www.youtube.com/shorts/ao6guBBVBvs |
What did the oil look like upon disassembly?
http://forums.pelicanparts.com/uploa...1709489169.jpg |
If your mechanic can’t figure out why there’s metal in your oil or why it’s making a metal on metal screeching sound better find a new mechanic. Why line bore a 3.0 unless there’s damage? What’s the mileage/history?
Ditto Dpmulvan's comment. Other possible sources of noise are, the throwout bearing, timing chain and sprockets.
Your verb tense is confusing. You said the "block is line drilled." Do you mean you have already fully disassembled it, inspected it, and "line-bored" the "case"? If so, were there any signs of main bearing or rod bearing damage? How about damage or wear on the sprockets, chain, tensioners and guides? |
Sorry. I'm from Europe and my English is bad :) The same mechanic previously rebuilt the engine.
He wants to get it right this time. . Block was inn for check. The bearings looked ok, no wear. Some deviation in roundness, the plan is now 0.25 over-dim bearings. |
No problem on the language. I just need to make sure what you are saying. :)
How many kilometers since that mechanic rebuilt your engine? |
You need to search it out. A good way is to take a a couple of feet of 10mm rubber hose and hold one end to your ear. The other end is used to locate the source of the noise. Also a good way, if the noise is internal is a mechanics stethoscope.
http://forums.pelicanparts.com/uploa...1709577878.png |
So how did your rockers and cam get damaged? Screw up with timing right?
Why many of my rockers and camshafts were damaged is surely also a good question? :) |
| All times are GMT -8. The time now is 12:38 AM. |
