Engine component specs
Where can I get dimensional specs for 2.0 liter six components.
TOT |
Senior Member
????????? What do you mean dimensional specs?
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Dimensions
Bad day at the ranch……Apologies to Dpmulvan!
TOT Last edited by zztot; 03-13-2024 at 05:19 AM.. |
Senior Member
PCA Member since 1988
Bot?
I know it shows he joined in 2007, and posted 1931 times, but someone with that experience here would know how to ask a question. And he would know about the Tech Spec books.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-12-2024 at 09:24 PM.. |
Clarification
Trying to find where to get the information needed to check all the critical components. Seemed like a pretty simple question…..
I have always had shops do the heavy lifting …..…the guy who is always doing my engine build is a retired PCNA tech and asked me to get the specs. I’ll go sit in the corner.
TOT |
This?
Ed 1973.5 T |
Our host carries these…https://www.pelicanparts.com/byb-genuine-porsche/c-tools-books_c-books-technical-documentation_c-technical-books
Ward Komers 1984 944 Track Car - Sold 1968 912 Rust Bucket - Under Repair 1971 911T - Under Repair 2006 Carrera S - Sold |
Specs
I have gotten what I need…..Thanks all!
TOT |
TOT: Sorry about bustin' your chops. We've seen some odd requests lately and some spammers that get through the filters, so your first post looked a little "off".
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
TOT |
Senior Member
No problem, thought you where screwing with me.
