Oil pump/cooler donut o ring seals: red vs. green
I'm a bit confused on which type I should use for my 3.4 build, I already have the red (I think they are Elring brand) brand ones, but for something that critical as a oil pump I just don't want to risk it. The problem is I can't find the original OEM ones in stock in any vendor. Any good/bad stories about the red ones?
Never had an issue with either one.
^^^^^ What John said X2
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I think the Green ones are Viton. A newer material.
PCA Member since 1988
The oil pump is entirely inside the engine, so if these leak a little, that little bit just goes into the sump, not on the floor. For seals between the engine and the outside world, I'm more picky about using Viton. Bottom line, don't worry about it on the pump, as the others have said.
You didn't say which set of gaskets/seals you are using. Did you get the Wrightwood set? If so, just use what they sent you. It's the best set you can get.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-19-2024 at 10:56 PM.. |
