Senior Member
Which valves should I stay away from??
Hoping Henry or someone else can point me in the right direction for new intake and exhaust valves that won’t bankrupt me. $10 to $300 is a huge difference and I don’t trust the $10 ones and really don’t want to spend $200 plus each. Heads are 3.0 small port.Thanks
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
abit off center
I have installed thousnads of TRW valves which is part of AE Federal Mogul which also has their own valves. Used IV in the past but found QC not as good, valves getting thru with nicks in the stems etc. Never had an issue with any of them. Id be more concerned with the valve guides and finish of the guide.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Senior Member
Senior Member
1000's??
Ok lots.... We not got close to that number of TRW valves, but never had an issue. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
