Deck Height 1mm - base gasket thickness
What are the advantages/disadvantages of using a 0.5mm vs 0.25mm cylinder base gasket in terms of deck height? I know stock is 0.25mm but many builders like 0.5mm.
Anything else I should know regarding thickness on the base gaskets? |
Thicker equals lower compression..
Bruce |
Thicker equals worse combustion chamber squish and less efficient burn.
That said, the important number is the clearance between the piston and the head. Use base shims to get that in the right range. I'm a minority, but I want as tight a clearance as I can get without contact. Generally around .030"/.75mm. It takes a lot of test assembling and measuring to get that accurately, so engine builders will not do that unless you specify it. |
Thicker may be necessary if your machinist took .010" off of your cylinder spigots when he leveled them or if the case halves themselves were machined after align boring. There you may need thicker base gaskets just to have the correct piston to head clearance.
Your post is a touch confusing.
You have measured 1mm deck height? or you are trying to achieve it? Cheers |
I've not heard of one gasket being better than the other. You pick the thickness that meets your need, to achieve the piston to head clearance you're aiming for. Every engine is a little different, especially if the heads have been cut, case decked, etc. First decide what piston to head clearance you are aiming for, e.g. .040", .050", etc., and then a mockup assembly tells you which thickness base gasket you will need to achieve that.
During refresh, I ran thicker and reduced squish. I swear squish made better performance everywhere. |
If that were my engine, I would have left the shims the same, and simply clearanced a few thou off the piston where I thought I saw contact with a hand file. Then I would get the just necessary clearance and better squish. For data collection purposes: How much was cut off your heads? |
I wished I could remember, but “cgarr” did them over a decade ago. Sorry.
When heads are cut, the machine shop will often stamp something like ".25mm" or ".010" on the heads.
| All times are GMT -8. The time now is 02:40 PM. |
