-   -   3.0 Engine Rebuild Sanity Check (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1159880-3-0-engine-rebuild-sanity-check.html)
PeteKz 04-12-2024 01:25 AM
Mat, since you will use the 993 pump, think about what to do with the extra oil it puts out. Otherwise, you will just dump more oil past the pressure valve into the return line. Ask William about that too. He will have some suggestions.
86 911 04-12-2024 01:49 AM
Ok thanks - will do!
jac1976 04-12-2024 07:50 AM
Ran across this by following one of the YouTube channels someone rec’d in another thread:
https://islandworks.one/products#!/products/integrated-thermostat-and-filter-console-with-dual-cooler-output
