crank/rods
So im test fitting a rod on a crank. When i have the crank horizontal and i turn the rod on the journal, i can hear it slightly touch the crank on the sides at times, i believe its called the thrust . If i have the crankshaft vertical, where the gravity is pushing the rod down against one side of the crank thrust, and i spin the rod, i hear it rubbing / touching even more.
Is this normal?
or should it be silent with no touching? I have clearance as I can move the rod side to side a bit, which i suspect is normal.. but not sure if clearance is even all the way around.
how could i determine if the bore on the big end is square with the rod. Would that cause it to rub? It was resized by a machine shop but is there a way to double check?
thanks in advance
Old 05-25-2024, 06:47 PM
PCA Member since 1988
Machine shops have special tools/jigs for checking and rebuilding rods. No easy way to do it at home. Check that the side clearance is the same all the way around. Tech spec book says 0.20 - 0.35mm or .008"-.014".
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-26-2024, 02:32 PM
Banned
Is this normal?
thanks in advance
How are you test fitting?? New Bearings Old bolts torqued to spec?
Old 05-30-2024, 08:45 AM
New bearings- torqued arp bolts to 30ftlbs.....should be 40 when fulled torqed.... Im guessing its normal to touch slightly.? I don't see anything that could prevent it from touching, especially when the crank is vertical.
I just seen videos where people spin them and it dont look like they are touching anything.
Old 05-30-2024, 08:54 AM
JoeMag's Avatar
the handful that I've done the crank is polished on the area where the side of rod BE touches it and the rod is smooth on that area too, so if there's any oil they spin pretty freely.
Old 05-30-2024, 09:17 AM
