Timing Chain Housing & JB Weld
As noted in the rebuild book I'm replacing the original material covering the inserts on the outsides of the chain housings with JB Weld. As I was doing this I noticed that the factory used their material on the inside of the housings to cover the two studs that go all the way through. Is it recomended to use JB Weld on the inside of the housings or is there another alternative to use? As popular as it is I've had no experiance with the JB product untill now.
By inside, you really mean outside, though? Inside would be inside the engine - I have never seen that...
-Wayne |
Yup there is some on the inside. Here are a few pictures. It's the same material as whats on the outside. At least it looks that way to me.
Left Side Cover http://forums.pelicanparts.com/uploads/camcovers333.jpg Left Side Cover http://forums.pelicanparts.com/uploads/camcovers111.jpg Right Side Cover http://forums.pelicanparts.com/uploads/camcovers222.jpg |
Any suggestions on what to use for the inside?
While you're on this topic, I have noticed that the post that supports the chain tensioner on the left housing has crept back a bit out of the rear housing, and now is blocked in place by the cooling fins of cyl # 1. It has only moved about a 1/4 inch out of the housing and can't move any further. Without opening up the front cover, would the tensioner still be supported adequately or is this a ticking time bomb?
To answer your question I'd say ticking "time bomb" but I’m not an expert and that’s my 2 cents worth. You might want to wait till some others chime in. By the way... does anyone have a recommendation for re-sealing the exposed internal studs? |
That stuff looks to me like the loctite 574 porsche used to assemble the engines at the factory. Just thinking out loud
Ben |
Nope, 574 is a case sealant - not an epoxy. Just place a dab of the JB weld on each of those external spots (after cleaning them off), and you should be fine.
I'm not 100% sure about the inside spots - I'll have to check a pair of chain housings and take a look - I can't remember off the top of my head. -Wayne |
Wayne,
You are correct in saying that 574 is a case sealant quite similar to 515, and 518. It is only set by squeeze or "pressure "as the loctite Rep always tells me. It can though set up over time a long time to look some what like the picture. A side note is to be very carful when choosing epoxies as not all are designed for heat. I have found that Honda-bond or yama-bond work well for this type of application as they do not require pressure to set and it can take a good amount of heat. Best regards Ben 77 911 3.0 75 914-6 2.7 |
| All times are GMT -8. The time now is 02:55 AM. |
