@porscheprojekt
Oil Hose Issues
Hello everyone,
I've rebuilt a 2.7L engine and just put it in a '68 912 body. There was obviously no oil tank, so I retrofitted an SC oil tank. The S hose fit perfectly but the other oil hose appears to be too long. I can screw in both ends but it creates a big kink.
I've attached some pics of the oil line. Pic #1 is the hose I'm using. Pic #2 is towards the rear of the car. Pic #3 is toward the front of the car. Pic #4 is of the hose connected only tot he tank. You can see how long it is.
Could someone give me some advice on what I'm doing wrong? Is it the correct oil line for my application?
Thanks for your help,
Jeff
'68 912 body
2.7L engine
Solex Cams
Weber Carbs
SSi Heat Exchangers / Monty Muffler 2-in/1-out
Old 05-22-2024, 10:43 PM
Calling BoxsterGT
206 637 4071
Old 05-27-2024, 05:39 PM
Shorten hose. Cut collar off, buy new collar from Belmetric, take to local hose making shop to crimp collar.
Old 05-27-2024, 05:51 PM
kgieg's Avatar
too long hose?
I'm not an expert at engine swaps but my thoughts are....
1. tank not in the right place (but you probably got that right).
2. short wheel base car hose shorter than LWB car, check that.
Hope you find the solution without mod-ing the hose.
A fair exchange is no robbery.
Old 06-12-2024, 01:03 PM
kgieg's Avatar
Just looked and Pelican cant confirm fit of that part number to a 68 911, so might be the problem.
Old 06-12-2024, 01:10 PM
Do what Porschedude996 suggested.
Cut off collar shorten the hose have hose shop crimp on a new collar.
Old 06-15-2024, 11:49 PM
Emo993's Avatar
Having a new hose made is the way. But I went the unorthodox fix on my 914-6 GT Tribute. The oil line from tank to engine had a hard kink when I added the check valve. 3/4 inch copper pipe is a perfect fix for a 90 deg angle. Best, Mark
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 06-16-2024, 04:34 AM
It's a 914 ...
stownsen914's Avatar
It may be a short wheelbase chassis with long wheelbase parts thing, as suggested. I wouldn’t be happy with a kink in an oil line, you’re right to address it. Len Cummings can fix that, or a local hose maker if you source the correct parts.
It won’t take much shortening of that hose to make it right. Maybe only 1/2 - 1”. Remember the engine moves around a bit, so you want a little flex/slack in the hose. You don’t want to turn that hose into an auxiliary engine mount. Could overstress it and cause failure.
Old 06-16-2024, 06:32 AM
BoxsterGT's Avatar
Porsche Crest
Just did this for another Pelican member.....
Please email me for info. NO PM's, box is full.
len.cummings @ verizon.net but without the spaces.
Old 06-18-2024, 08:40 AM
BoxsterGT's Avatar
Porsche Crest Oil Supply Check Valve
Emo993-
Re- Above post, just wondering how this Oil Check Valve worked out with your 914-6?
Thinking of this for my project Six.
Len
Old 06-27-2024, 11:59 AM
Emo993's Avatar
Hi Boxster GT, Check valve works great, just had to create a smooth oil path to it. The 3/4 copper pipe fits nice in the 22/23 mm ID hose. Best, Mark
2007 Cayman S
Old 06-28-2024, 04:23 PM
saladin's Avatar
Hello Boxster GT,
Checking in to see if you received my May 11th email to len.cummings @ verizon.net regarding the 914 six conversion custom oil hard line mockups I sent you.
Ken
Old 07-07-2024, 09:32 AM
