2.2 options > is 10.5:1 too much?
Hi, i ahve bought what appeared to be 10.5:1 85mm JE pistons.
Been told that they will be too much compression to run on pump gas. Ive read that there is 2 ways to reduce comp ratio:
1) use copper gasket between the cylinders and heads
2) remove material from the dome.
Any opinions?
PCA Member
2009 Audi A3 2.0 Quattro
1978 911 SC Targa
Old 06-25-2003, 08:16 AM
PRO Motorsports
Tyson Schmidt's Avatar
Yes, that is too high for pump gas unless you twin-plug. You should install copper base gaskets that are .50mm thicker than what is required.
Example: Stock is .25mm, and if the heads were machined another.25, then you'd need .50mm base gaskets. Then, to lower the compression, you'd use a copper gasket that is another .50mm thicker, therefore, you'd install 1.0mm base gaskets. Depending on combustion chamber volume, this should roughly reduce the compression a half a point.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-29-2003, 06:31 PM
