Juicing the 911 SC-L 3.1 Leistungsgesteigert
Engine type 930.03 or 930.09 * 3.1 *
Engine displacement: 3122 cc Bore x Stroke: 97mm x 70.4mm Power: 210 hp @ 5900 rpm Binary: 280 Nm @ 4300 rpm 0 at 100 km / h: 6.4 seconds Max speed: 230 km / h The Forgotten 911SC-L Porsche's 1st factory tuning engine kit that was NOT in the option list for those years (Dealer Secret) Rolf Sprenger, The Father of the Porsche MFI for the road cars and the Slant Nose 930 Designed this 3.1, 210hp Tuning kit for customers that were not happy with the output and performance of the normal 911SC 3.0 78-81 This tuning kit has a output of 210HP @5800 RPM and 206 Torque @ 4700rpm Roth used 97mm 3.3 Turbo Cylinders with 9.5:1 compression Pistons made it 3122CC 3.1-L Engine Leistungsgesteigert or Increased Power Bosch reworked the CIS injection with new Distributor Taller 5th gear and larger oil cooler from the race department 3750.00 dollar Option in 1978 ONLY spread word of mouth at Porsche Dealers showroom when customers voiced displeasure of the performance of a normal 911SC Never was available in the USA only Europe and ROW and only a Letter from Rolf was included in the glove box with this upgrade No way of knowing how many of these tuning kits were made Some estimate 200-300 unit made Roth Sprenger Personal notes and Porsche refusal to Market the SC-L almost left no documentation to this special rare 911. We are replicating this unique forgotten option for immediate sale . Click the link and you're on your way. http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1163435-porsche-911sc-leistungsgesteigert-piston-cylinder-kit.html#post12271448 |
Real nice power kit this [emoji123][emoji4]
Sent from my iPhone using Tapatalk |
How will this work for US spec engine?
Are the performance numbers noted specific to a large port engine?
How well would this set-up work w/ a US Spec small port (1980) engine? |
Pondering that same question.
In the 1980 and later (small port engine) they incorporated an oxygen sensor triggering a frequency valve that adjusted the fuel distributor to create a lean running condition. Then they put that exhaust through a catalytic converter, The larger pistons with slightly higher compression can only be beneficial to any measurable extent if you can meet the additional fuel requirements to create the performance desired. So the answer is, the kit will only add performance if properly tune. That may require a cleaner exhaust, a better fuel distributor, removal of smog equipment and of course cams. As far as the small ports and runners are concerned, as long as the goal is performance under 6400 rpm, the small ports can prove to be easily workable. |
An additional thought:
With some creative rod configurations and crank combinations you can make 3.3. |
Holiday Bump
Still available
