-   -   Acceptable wear on intermediate shaft gears? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1163707-acceptable-wear-intermediate-shaft-gears.html)
stownsen914 06-30-2024 01:05 PM
Starting to assemble a 3.5L engine, and noticing some wear on intermediate shaft gears I didn’t notice on teardown. I’m hearing that new gears are not great quality, so wondering what is the threshold for replacement. I don’t see any wear at the root of the gears, but do see some on one side of one row of teeth. Similar on the other gear.
stownsen914 06-30-2024 01:09 PM
Weirdness posting pics, let’s try again.
http://forums.pelicanparts.com/uploa...1719778049.jpg
http://forums.pelicanparts.com/uploa...1719778099.jpg
draw 07-01-2024 08:45 AM
I'm no expert, but here are my gears for comparison. I decided to replace mine with genuine Porsche parts. And I was taught long ago, whether it's right or wrong, to replace chains and sprockets as a set no matter if it's a bicycle, motorcycle, timing chains, etc. So, I'm replacing the chains, intermediate shaft sprockets, and the camshaft sprockets for my build.
http://forums.pelicanparts.com/uploa...1719848571.jpg
stownsen914 07-21-2024 09:09 PM
After examining the intermediate shaft and cam sprockets more closely today, I found wear in the U between the teeth, and some transition areas can just catch the tip a small screwdriver as I gently drag it over. Just ordered new sprockets.
