-   -   Newbie heads porting & heat exchanger question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1164002-newbie-heads-porting-heat-exchanger-question.html)
profblue 07-08-2024 03:44 AM
Rebuilding a 2.4 engine, and I have the ports ported from 32/32 to 36/36mm. I am just pulling the trigger on new stainless heat exchanges, and only see essentially 2 models (MFI and carbs). My questions:
- What are the port sizes of the heat exchangers? are all 32mm, or are they larger?
- Is there a need to have these machined, or does it not significantly if these are not matched up, ie. 36mm from the heads into the 32mm of the heat exchanger?
Thanks,
MST0118 07-08-2024 04:57 PM
I think the normal SSI heat exchangers is 35mm inner diameter which is about 1 & 3/8 inches. Btw, your 36/36 port sizes are close to what was on the 73-76 MFI Carreras that had 36/35 ports. I’m not sure of the ID size of standard 2.4 heat exchanger though.
stownsen914 07-09-2024 05:29 AM
I’m not aware that Porsche built different diameter versions of the early heat exchangers for 2.2/2.4 models. You should be fine at 36 mm with stock ones.
