-   -   3.6 track engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1164354-3-6-track-engine.html)
r lane 07-16-2024 05:55 AM
3.6 track engine
I am building a 3.6 track motor with CR being 12.45 to 1.0. Was thinking I wanted no more than 12 to 1. I can remove 1.6cc from the dome and get it down to 12.0. I don't know a magic number for compression on these motors. The 3.6 is I think more susceptible to blow by due to the additional span of its cylinder heads. does a half point matter. Any good info greatly appreciated. Bob
Henry Schmidt 07-16-2024 06:10 AM
Cylinder head stability is primary. Of course I would recommend Supertec Head studs no matter how much compression you choose.
I believe there is very little performance difference between those compression numbers.
pocv0 07-16-2024 07:40 AM
This is where you will get schooled on static compression and dynamic compression from the board.
The last 993 3.6 liter I built was 12.5 : 1 CR (static,JE pistons) , GE100 cams , twin plug ,Carrillo rods and on the dyno 319 RWHP. Of course this was on race fuel. If this is for a track car why do you want to lower compression? Blow by? I didn't have any issues, logged around 30 track hours on the engine then sold it.
