-   -   Unique cam nuts and washers. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1166401-unique-cam-nuts-washers.html)
Geneulm 09-01-2024 06:31 AM
Have a set of cams that are part of my build that originated as a set of rsr cams. They use a fine threaded nut. Anybody have a set around?
Flat6pac 09-01-2024 09:45 AM
40 years and I had one set on rsr and I believe from memory they are 32mm on the shoulders. Check with the size but I know they weren’t 46mm.
Bruce
Geneulm 09-01-2024 07:21 PM
Yes. Smaller. But also different threads
Dpmulvan 09-02-2024 06:29 AM
Check with Henry.
JimmyT 09-02-2024 09:24 AM
Hi Gene,
WET '65 906, Fig 1-4, #70, 901.105.173.00 Nut for camshaft [Mutter für Nockenwelle] Qty: 2
Ti, Polished, $29.82 each
http://forums.pelicanparts.com/uploa...1725294185.jpg
I emailed you a copy of this post.
Jimmy
Geneulm 09-02-2024 09:56 AM
This place is incredible.
Jim, I sent you an email.
