-   -   Case Hardware Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1168795-case-hardware-question.html)
86 911 10-13-2024 07:26 PM
After many months, I am going to put my 3.0 SC engine back together. Tonight, I opened my little baggie of case hardware and cleaned everything up.
I will be replacing the washers and nyloc nuts. I noticed that the original nuts are yellow zinc. I purchased clear zinc coated steel nyloc nuts (see baggie at the top). I assume these are fine?
Also, can I re-use the beveled case thru bolt washers? I am referring to the three washers in the bottom of the photo (of course there are a lot more on the thru-bolts not shown here).
http://forums.pelicanparts.com/uploa...1728872671.jpg
Dpmulvan 10-14-2024 06:38 AM
Yes you can reuse the beveled washers, nuts are fine if you want them yellow dip them in a dilute acid 5% rest water for 30 seconds followed by a 30 second dip in sodium dichromate.
86 911 10-14-2024 11:33 PM
Thanks for the info!
PeteKz 10-15-2024 02:42 PM
Agree with Dpmulvan. Those look pretty good in the picture. If they are not pitted with corrosion, reuse them.
gsxrken 10-16-2024 12:47 PM
My one minor regret in my own engine rebuild was not to ship off all the hardware for refinishing while the major parts were out being machined etc.
Does it add HP? Nope. But it just looks so much nicer. And that's part of enjoying a hobby too.
Future engine builders: add it to the punch list!
PeteKz 10-16-2024 03:39 PM
Hah! After you put the fan shroud and induction on, you won't see them.
Jeff Alton 11-06-2024 08:30 PM
We clean, tumble and replate those parts....
Cheers
Undecided 11-07-2024 01:21 PM
Go titanium :)http://forums.pelicanparts.com/uploa...1731014490.jpg
