-   -   Can 50 PMO itbs work on a 3.2 SS? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1168826-can-50-pmo-itbs-work-3-2-ss.html)
Axel84 10-14-2024 03:47 PM
I have a 3.2 SS on DC60R cams, twin plug big port heads 39 mm - full rarly longtube headers exhaust. I have The chance to aquire a set of PMO itb 50 mm from a 3.2 race engine , 43 port size for a good price. Can this work on my engine or just too big? I can take my port size up if needed Thanks
Classic 911 10-15-2024 01:52 AM
Interesting question [emoji106]
prschmn 10-15-2024 04:02 AM
You can make it work but I'd suggest not uping the port size, you need velocity there
to keep it driveable.
zztot 10-15-2024 04:59 AM
Carb question
Several years ago a shop installed new carbs on my somewhat modified 3 liter. It would scream at full throttle but feathering was impossible. We talked with Richard at PMO and he said nothing wrong with carbs just too large. I recall him saying 3.6 was smallest suitable for 50s, but your 3.2 may be strong enough to handle. Went back to 46s and it was fine. My comment is not based on anything but that experience, but there are a several on here with the knowledge to weigh in ……like Henry.
prschmn 10-15-2024 06:46 AM
You should look to see what size chokes in in the 50s.
You may be able to get smaller ones.
r lane 10-15-2024 01:20 PM
They will definitely work on a 3 liter race car. Even if you have 12-1 compression, probably not the set up for the street. On the street you are operating between 2 and 6000 rpm. At the track between 5 and 7500 rpm. Big difference. Bob
Axel84 10-15-2024 01:45 PM
yeah wont have 12 compression, probably 10:1
targa72e 10-15-2024 02:27 PM
Many of the comments are assuming these are carburetors. Going with too large of a carb can make the signal to the carbs very weak making street driving hard.
It sounds like these are ITB's for electronic fuel injection. Larger size might hurt low end torque but is less of an issue than too big a carb.
john
Axel84 10-15-2024 02:35 PM
ITB EFI`s , not Carbs!
zztot 10-15-2024 03:58 PM
Comment
For those old enough to remember…..In the words of Emily Latello one of my favorite Saturday Night Live characters………….Nevermind!
Need to pay closer attention to what I am reading……Sorry for diverting your question.
r lane 10-16-2024 06:30 AM
Yep, saw PMO and quit reading and assumed carbs, so don't know but would still think a bit spongy down low. Bob
prschmn 10-17-2024 04:29 AM
Duh-guilty here too!
Evan Fullerton 10-17-2024 11:19 AM
If we look at the motorcycle world.
1000cc V-twin Super-bikes from the early 2000s all used over 50mm throttle bodies……. That would be a 3.0L 6 cylinder……. But they also rev’d them over 10,000 RPM.
On a 8,000+ RPM SS 3.2L race motor, 50mm should work, you might just loose some part throttle resolution vs. 46mm ITB.
The 914 I Autocross we are building a new 2270cc T4 for that we will spin over 8000 RPM. That’s getting 48mm Carbs as the 44s are already a restriction on the 2056cc motor that’s in there. 2270cc T4 equates to a 3.4L -6.
winders 10-17-2024 12:39 PM
Too big....
stownsen914 10-17-2024 01:04 PM
Agreed with other comments that they'd be a bit large. Notably if they are 43 mm at the base and your heads are 39 mm, that's a significant size mismatch.
winders 10-17-2024 03:10 PM
That is going to ruin airflow speed and makes things much worse. Increasing the intake port size to 43mm is a bad idea too. They are just too big for the engine....
winders 10-17-2024 03:13 PM
If you want a great performing ITB setup, get AT Power 42mm or 45mm ITBs matched to your 39mm ports. That will blow away any PMO setup....
https://www.atpower.com/products/porsche-911-throttle-installation-efi-kit-with-ecu-engine-harnesses-and-base-map-package-model-years-1978-1989
Axel84 10-18-2024 12:05 PM
Carrera heads Are 42.5 are they not? Port size. So why wouldnt opening them up to that size work
Classic 911 10-18-2024 01:33 PM
https://uploads.tapatalk-cdn.com/202...458cd6e544.jpg
[emoji6]
Axel84 10-18-2024 01:58 PM
Thanks 40/38 got it
Classic 911 10-18-2024 03:06 PM
Originally Posted by Axel84 (Post 12341843)
Thanks 40/38 got it
[emoji106]
Maybe Mr. "hylla" has a 3.2 Carrera head so you could measure the port size yourself [emoji6]
Evan Fullerton 10-18-2024 04:12 PM
For what it’s worth, I told Bill at Xtreme I was building a SS 3.3L that would make peak power around 7200 and he still recommend a 42mm intake port to go with the 53mm intake valves. He wasn’t remotely concerned about loss in air speed on only a 3.3L
winders 10-18-2024 05:37 PM
My problem was mainly with the port size mismatch and having air bounce off the lip created by using ITBs with 43mm ports on 39mm intake port heads.
The problem with the ITB setup asked about is the combination of ITB size and port size on a 3.2SS engine. 50mm/43mm is just too big for a 3.2 street engine.
Also, My 3.746L race engine that makes 450 HP and revs to 8,000 RPM uses Xtreme heads with 52.8mm intake valves and 45mm intake ports. There is no way a 3.2L 7000 RPM street engine should be using 53mm intake valves. Nope. That makes no sense at all. With those intake valves you need 1 3/4" headers to match them. Again, that makes no sense at all. All that does is slow down airflow into the engine and destroys low-end to mid-range torque.
Classic 911 10-19-2024 06:09 AM
https://www.motortrend.com/how-to/0507ec-porsche-911-sc-carrera-machine-work/
Classic 911 10-19-2024 06:31 AM
Here from Rennsport Systems:
https://rennsportsystems.com/letstalk/ignitions-cylinder-heads-pistons-cylinders-and-the-bottom-end/
https://uploads.tapatalk-cdn.com/202...1afcee4c37.png
https://uploads.tapatalk-cdn.com/202...8d6edda4e8.png
https://uploads.tapatalk-cdn.com/202...aa8b040269.png
https://uploads.tapatalk-cdn.com/202...d90b23a23f.png
Robert Espeseth 10-26-2024 11:32 AM
Axel, will get some 46's in to AB Garage soon, that will be a better fit for your set-up :)
totle 10-27-2024 12:38 AM
Cool and agree
