Question Opinions on Pre assembly
Opinions needed.
This might be a touchy subject but have a question for you engine builders out there. Let me start out by saying, I don't want to sounds like a guy trying to squeak by or take a short cut but I know that very well may be how it comes off. Looking for experience in which I'm lacking on this engine. Currently in the process of building my 1980 911sc. Pistons and Cylinders are mounted and have checked for deck height via the acid core solder method. Everything there checks out well (1.3-1.5mm) with .25mm cylinder base shims. In Wayne's book, he recommends pre-assembling everything and checking for valve clearance, disassembling everything, and then doing a final assembly. He also goes on to say that unless major modifications were made, this usually results in good numbers/clearance and is primarily a making sure your efforts are not dashed l. So here where you all come in... I have had cams reground to 964 specs, heads have all been rebuilt with OEM parts but resurfaced with .22mm cut, pistons were replaced with new Mahle euro spec 9.8.1 pistons. No machine work to the cam boxes or case halves. Bottom end was not split, so original crank and rods. Think I'd be an idiot for not preassembling? Im not apposed too but if I'm being a bit overly cautious I'd like to not waste my time(I know it's not a waste of time per say to know its good, but you know what I mean). So give it to me, what you think?
Thanks for the input!
Old 09-13-2024, 05:05 PM
PCA Member since 1988
How many of these engines have you built? If this is the first or second, I recommend you do the test assembly. If you have done this a dozen times, you wouldn't be asking.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-14-2024, 12:58 AM
targa72e's Avatar
Lets see, new cams, pistons and machining. I would test assemble and check for clearance. Its not that hard.
john
Old 09-14-2024, 11:40 AM
vl5150's Avatar
I preassembled everything on mine and checked the valve clearance. I also picked up a burette and measured my chamber volume and piston dome height while I was at it to calculate my compression ratio.
Old 10-03-2024, 04:37 PM
I would be very leery goin through all that work and not having checked oil pump , replacing # 8 oring and resealing all fresh .. Just a piece of mind..
Old 10-03-2024, 04:43 PM
Senior Member
john
Not hard just a major pain in the butt.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 10-04-2024, 06:26 AM
targa72e's Avatar
I kind of like it
john
Old 10-04-2024, 09:54 PM
Senior Member
I kind of like it
john
Next your going to tell me you like mowing the lawn (sober).
Old 10-14-2024, 06:54 AM
targa72e's Avatar
I don't like mowing the lawn sober (or with a cold beverage either)
I do like measuring, CCing, checking clearances, machining etc. I find it relaxing.
It also allows me to do component matching. I can put the biggest piston with the biggest cylinder, tallest head with shortest cylinder, etc. none of these items are identical (especially if used and/or machined).
I have gotten items back from the machine shop and on measuring found them to be out of spec and had to have them redone (they were spot on the second time).
Also, this way I know what I actually have vs assuming things will be ok.
john
Old 10-15-2024, 02:51 PM
Senior Member
john
I’m just busting on you, Had plenty of issues with local machine shops that’s why I switched to Craig. At the cost of building an engine you’d have to be a fool to make assumptions and not measure, recheck your measurements.
Old 10-16-2024, 07:06 AM
