And, if you narrowed the engine overall without adding shims under the cylinders, your pistons may be getting too close to the heads and valves. Check the clearance, if you haven't already.
The larger idler wheel and machining the tensioner box solved this. Thanks for all the input!
| All times are GMT -8. The time now is 11:58 PM. |
