3.2 Engine Case, Oil Galley Plugs - Generic Plug ok?
Just making sure the general consensus is ok with using "generic" oil galley plugs here.
Took the old one out when cleaning the cases. PET PDF does not list it. Thank you! ![]()
I’ve seen the machine shops use 3/4” freeze plugs instead of 22mm, check my math. The metric ones aren’t hard to find.
I wish I had never taken these out. Didn’t need to. Now my machine guy is trying to help me machine the right size. The first plug was able to push in by hand. No good. Apparently you’ll need to tap these in. Gunna try one at 22.35
1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger Last edited by stubble88; 06-20-2025 at 09:13 PM.. |
I just bought a set of these plugs at Patrick motorsports.
Jesse '76 911 backdate with Carrera 3.0 engine |
The 9 Store
We make them on a lathe then freeze before tapping in.
All used parts sold as is. |
It's a 914 ...
In case our host doesn't sell these, another option might be machine shops that specialize in Porsche like Ollies or Competition Engineering would sell these. EBS may also be able to help
Part number is 911 101 185 00 for 22 or if you need over sized 911 101 185 01 for 23mm.
75 911s 86 951 sold to make room for baby seat 09 335i 6MT NVH |
Thank you guys
