-   -   what is this part? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1171078-what-part.html)
jonbeatty 12-04-2024 01:36 PM
what is this part?
I am rebuilding a RoW 3.2L 911 engine and while restoring the throttle body I took this part off. It appears to be a sensor of some kind but the two connections appear to be small vacuum lines. There is no electrical connection.
I suspect it is a one way valve that is thermally controlled?
I am trying to understand it so I can test it to verify it is still functional.
[IMG]http://forums.pelicanparts.com/uploa...1733347979.jpg[/IMG]
brighton911 12-04-2024 02:10 PM
It is a thermo time switch that sends vacuum to the oil tank PCV.
jonbeatty 12-05-2024 11:53 AM
Thx for the quick reply. I Googled thermal time switch and all I can find are ones with electrical contacts. Any chance you have a part number? Or, do you know how to test it?
Ok, someplace I think I have an old copy of PET so might have to find a way to read that CD. ;-)
E Sully 12-08-2024 05:39 AM
https://www.pelicanparts.com/More_Info/93020723101.htm?pn=930-207-231-01-OEM&bc=c&q=930%20207%20231%2000
MasonGreen 12-11-2024 12:43 AM
I’m not sure exactly what that part is, but it sounds like it could be a thermal vacuum valve or a similar component involved in controlling vacuum flow based on temperature. I’d also love to know more about it and how to test its functionality, anyone have insights on this? When I was pressed for time with an essay assignment, I turned to https://oxessays.com/write-my-essay oxessays. The service exceeded my expectations. The essay was completed on time and was of excellent quality. The writer followed all my instructions and provided a clear and concise paper. The customer service team was responsive and ensured everything was in order. I will definitely be using this service for my future assignments. Highly recommended!
