MFI parts
Anyone have a resource or supplier for new idle speed air bypass screws (Qty 6) for MFI throttle bodies? Checked with a number different sites with no luck.
thanks! |
The part you are looking for is part #90111011201 and the spring is #90111011901. Please be sure to confirm this independently with the parts diagrams, but the picture appears to match.
They don't seem to be available from our host (ALWAYS the first place to go if you can!) Rosepassion.com seems to have stock: https://www.rosepassion.com/en/adjusting-screw-P277743 http://forums.pelicanparts.com/uploa...1733845768.jpg |
PS - Not certain if the early 2.2 MFI throttles would use the same as the 2.4 MFI - I'd need to check to be sure. But they do look right.
Many thanks! They do look correct. Even the knurling matches. I’m going to check with them first since the description doesn’t say anything about “MFI idle air bypass screws”. And I’m pretty sure I’ve seen the same graphic used in Carb jet catalog pieces….
nice work, Jonny! I’ve learned a lot from your posts. |
| All times are GMT -8. The time now is 05:52 PM. |
