Thanks Henry,
Short related question, as being calibrated for a 2.4S, you mean that it still needs to be tuned (on a dyno or air/fuel ratio sensor) or will it run already proper with the standard 2.4S calibrated pump!? |
What I'm suggesting is that the 2.4 space cam will offer reasonable performance. MFI is an imperfect system with limited versatility. They never run "perfect" but with a reasonable expectations, you should be happy with the compatibility. |
Question for Henry
You have given council earlier ….plus have your rockers. It is old school Mahle S p/c 9.8CR, DC 30, head work including 46/40 valves SC springs,and porting. Two things in question….Bosch distributor 008 w pertronix Planning Webers (IDTs)with 32 Venturis but need remainder of set up for Webers Specifically E tubes and jetting. Would appreciate any guidance. Thank you! |
| All times are GMT -8. The time now is 09:48 PM. |
