-   -   Converting early distributor question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1173539-converting-early-distributor-question.html)
zztot 02-04-2025 11:32 AM
I am having a 2 liter six built from T specs to S p/c, bigger valves , DC 30 cams etc.
Changing Marelli distributor to Bosch…..but not sure I bought the correct one (of course)
Have a Bosch 0231 159 008 ( it has 1-2-3 in it)
Thanks for expertise.
Flat6pac 02-05-2025 04:11 AM
The shaft of the distributor changed size for 72
What you have, if it fits, use it.
Bruce
zztot 02-05-2025 06:15 AM
Dist
Thanks Bruce… dimensions look right.
May have misstated it has Petronix(? ).
There is an extensive thread going down a rabbit hole……but talks about tach working. Any issue there?
mskala 02-06-2025 05:28 AM
The 911T distributor curve is different from the 911S/911E curve. So either get the 006 or 007, or have yours recurved. Also, not sure of what flywheel is what, but put a red line at 30 degrees if yours is 911T or 914-6 (which would have had 35 degree marking).
ed mayo 02-06-2025 09:09 AM
It has a programable 1 2 3 distributor, make it whatever you want.
Rosco_NZ 02-06-2025 09:50 AM
Think he corrected himself and went from 123 to Pertronix. 123 would not be old distributor with part number.
Bend911 02-10-2025 01:00 AM
If you find that you need a distributor I have one out of my ‘75 that Jerry Woods just recurved. I went with a 1-2-3 after working with Icarp. I can send the specs on my Bosch if you’re interested.
Lucas
zztot 02-10-2025 06:31 AM
Distributor
Send pm.. Thanks
Bend911 02-10-2025 12:33 PM
Just responded. Thanks!
