911 SC flywheel question please
Hi everyone
I’m building a 76 911 with an later SC case 80-83, however the trans is a 78-81 915 Does it matter what flywheel I use. Where there different flywheels between 78-81 Thanks in advance |
SC engine will have 9 bolt crank/flywheel, all SC’s were the same.
The later SC had a 3 bolt pilot bearing and the crank was drilled to accept the bolts. The flywheels are only different in terms of the mounting for the pilot bearing. |
Flywheel
Thanks for the info
| All times are GMT -8. The time now is 05:05 AM. |
