gasket sealer?
Hi
I was going to put together a 2.0 engine this week, I was wondering do you guy's use gasket sealer for the gaskets or just leave them dry? I do have 574 sealer for the case and the cam housing, this will do on the gaskets too? thanks Dave |
See www.101projects.com - the 574 *will not* work on paper gaskets - it is designed only to seal metal-to-metal surfaces. The one area where I recommend that you use it on a gasket is on the cylinder head base gaskets, which are copper.
-Wayne |
thanks ,
So.. I should leave the paper dry? |
| All times are GMT -8. The time now is 05:18 PM. |
