-   -   injector reccomendation (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1177557-injector-reccomendation.html)
r lane 05-09-2025 09:59 AM
I have a 92 Turbo, twin plug and converted to EFI. have Seiman 3102 55lb injectors installed at present. Would like to try a different injector as one of these is leaking, they are 22 years old and their spray pattern is a straight pencil. Have heard that there are multi orifice injectors that provide a cone spray pattern which I have to think is preferable. Any experience and suggestions. Thanks, Bob
winders 05-09-2025 04:39 PM
Injector Dynamics ID1050x…
With these injectors, depending on EFI, you can install an injector characterization profile that allows the ECU to automatically change dwell times based on fuel pressure changes.
Speedy Squirrel 05-10-2025 08:20 PM
So, that one is a low impedance injector (resistance around 2.4 ohms). If your ecu injector drivers can be switched between low and high you can use the newer high impedance injectors, like Siemens Deka 4. Quite a few options. Here is one.
http://forums.pelicanparts.com/uploa...1746933615.jpg
