Pulley install
I’m installing the Rothsport Billet Machined 145mm Crankshaft Pulley for Single-Belt Conversion onto my 993 3.6. Does anyone if it should just slide on the crank, or does it need to be tapped with a rubber mallet? The tolerances are really tight with the one I got. Just making sure. Thanks.
Heat the pulley with a map gas torch...it will slide right on.
| All times are GMT -8. The time now is 12:16 AM. |
