-   -   New service available at Supertec (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1179450-new-service-available-supertec.html)
PeteKz 06-28-2025 03:16 PM
Originally Posted by Henry Schmidt (Post 12488961)
Pete and Old H2S, let's try to stick to the topic of the thread.
We did. We took it to PM and email.
Cranky today? :mad:
Henry Schmidt 06-28-2025 03:27 PM
Originally Posted by Neil Harvey (Post 12489040)
You are hard work and as others have suggested show an underlying sense of hostility, so I'm going to pull back from adding to your posts and focus on my own "air cooled developments".
Good luck in the future.
In a thread about a possible solution to remedy a parts scarcity (very few 49mm cam housing on the market), you bring a suggestion about cutting down 49mm cams to fit in 47mm housings.
Why not cut the 49.00mm cam journals down to 47.00mm and modify the grinding sheets for the 49.00mm designs to fit the smaller journal cams. This is my approach so we can offer more modern A symmetrical cam designs for the earlier engines.
What you call hostility is actually impatience for arrogant responses. Maybe just saying you don't understand, would have saved you the embarrassment.
BTW: the other person who suggested I was "hostile" was referring to a post directed at you. Hummm?
Henry Schmidt 07-03-2025 11:16 AM
End product.
Restored cam tower/housing. 47mm converted to 49mm
This set is for sale in the 911 parts classified.
http://forums.pelicanparts.com/uploa...1751566455.JPG
Helix8 07-04-2025 03:39 AM
Cam towers/housing look great and someone will put these to good use. Nice work.
I cannot understand your constant hostility towards Neil. Is there a backstory? I don't see where you have received any arrogant responses from him. Is there something else, hmmmm?
Turbo_pro 07-04-2025 07:17 AM
This forum is about methods, techniques, products and services to make rebuilding air-cooled 911 engines as successful as possible.
I concentrate on who is offering the most complete information possible. Decorum and personalities are Low "T" diversions.
