Oil line adapter needed
Looking for vendor to make an adapter fitting to my later oil cooler ( threaded) to my
Rubber oil cooler line to oil tank … My rubber is for connections to stubs at both cooler and tank.. Thanks for assistance Frank |
The threaded factory cooler is the early. Depending on the engine, not very desirable.
Something sounds kludged up but an adapter fitting can be fabricated with very little effort. Post some pictures and Ill comment again. |
http://forums.pelicanparts.com/uploa...1752174704.jpg
http://forums.pelicanparts.com/uploa...1752174704.jpg http://forums.pelicanparts.com/uploa...1752174704.jpg Here are photos of connectors and hose I was proposing to use .. …I did measure both threaded ends at 32mm Maybe just the wrong hose for these connections… What correct hose .. Thanks Frank |
Thanks Jim…
Appreciate part # |
| All times are GMT -8. The time now is 06:21 AM. |
