-   -   Twin plug (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1180828-twin-plug.html)
Rick Cabell 07-29-2025 09:04 AM
Twin plug
Had an engine brought to me in boxes to assemble. I have little experience with twin plug applications. Attached is a pic of the JB racing dist. cap. I assume 1T means #1 cylinder top, and 3B means #3 cylinder bottom. Just checking my common sence.http://forums.pelicanparts.com/uploa...1753805007.jpg
MoreGAS 07-29-2025 10:43 AM
You're correct. It is a clockwise rotating distributor and if you have the correct rotor to go with it you will see the pins line up on 1T and 1 B at the same time , then go through the firing order each skipping a wire location through 360 degrees.
CheeRS
Kevin
GAS Motorsport
Rick Cabell 07-29-2025 11:48 AM
Thanks Kevin.
