Piston skirt coating?
I'm putting together a 2.7 motor with a new set of Nickies cylinders and CP-Carrillo pistons. Thoughts on having LN Engineering (or someone else) coat the piston skirts?
Rough idea for use is as a track day/canyon car. Not a full-blown competitive race car. A few other main engine components for context:
- Carrillo rods
- 46mm webers
- DC60 cams
- ~10.5:1 CR
Old 07-31-2025, 10:48 AM
JoeMag's Avatar
You can get them coated through CP too... I'd ask them what the pro's and con's are.
Old 08-05-2025, 09:52 AM
I ended up calling CP and doing just that. With the amount of money going into the rest of the build, for $40/piston the coating seems like a no brainer so having them do it.
Old 08-05-2025, 11:13 AM
The coating wears off to the right size for that bore and if checked later it will show the differences between each piston.
I'm not picking my nose..I'm porting my upper intake manifold.
Old 08-05-2025, 12:12 PM
I prefer WPC treatment since it is not a coating, but just as beneficial.
Old 08-05-2025, 12:17 PM
