Any experts recognize these rods? 2.8 race motor
Amy of you experts recognize who may have made these rods?
They are ~141mm and came out of my trick 2.8 Race motor. http://forums.pelicanparts.com/uploa...1754605644.jpg http://forums.pelicanparts.com/uploa...1754605656.jpg |
Hi
Those nice rods were shot peened at manufacture. Shame that someone attacked the caps with a Centre Punch one to six times ! Cheers |
They look like Crower Maxi-Lights. Could be something else, but the design looks the same.
Thank you, Deep Google search told me that might possibly be the builder. Original build was back in the 80s I think.
These are somewhat unique in that the rod bolts thread into the cap leaving more clearance around the big end. Most are the other way round.
Looks like every I-beam rods made in China. Not implying that they are bad, only that there are just a few factories and they do tonnes of rods for different brands.
You know China is older then the U.S.
They look a lot like the rods offered by MittelMotor in Germany. Not sure who makes theirs.
https://www.mittelmotor.de/racing/de/webshop http://forums.pelicanparts.com/uploa...1754679601.jpg john |
Looks like some didn't actually spot the difference in their boy's life books....
JMZ, are you the one comparing your rods to chinesium that look nothing like your rods? No sir. That observation wasnt directed at you; why would it have been, you're the one asking for help, and not really getting it with comparisons to parts that are clearly not identical. Sheesh.
I'll come at the question from a slightly different perspective.
I don't know who made these rods. In 40+ years of building these engines, I have never seen that design used in an air-cooled Porsche. That said, does it really matter? If you were thinking about buying these rods, "who made them" becomes far more important. You own them, they look to me to be well made and you have a history of success with them. If this is a 2.8, that would suggest that the B&S is 70.4 x 92. Very common in the day. Whoever built this engine was looking to improve the rod length to stroke ration in an attempt to help it rev. 141:70.4 = 2:1. This odd length may also suggest that the rods were designed for another application. Carefully measure the journal size. 2:1 is considered by many (including myself) the optimum ratio for NA engines for a couple of reasons. Increased rod angularity causes additional wear and often facilitates the need for off-set wrist pins. Longer rods reduce angularity and create additional piston dwell improving horse power output. With longer rods, the pistons dwells longer at TDC and it dwells less at BDC. The decreased dwell BDC can cause detonation. The perpetuity towards detonation in a Hemmy head engine means attention to dynamic compression becomes more critical. Knowing who made them is a nice foot note but not required to rebuild your engine. Obviously the long rod will create the need for custom pistons, so look to that issue carefully. |
Henry, thank you for your response.
I asked the question so maybe we could send back to the shop that made them to have them re-bushed. This engine uses 2.8 factory RSR 92mm pistons and a 70.4 crank with clever use of spacers, longer chains, modified fan shroud and a splice welded info the Weber cross bar. You might be about to help with another question. …cams are Elgin 306 288 102. Current heads that have been used for many years have I think 38 or maybe 39 intake port size. …not close by to measure. It is currently very easy to drive and if you set it up right pulls quite well out of corners. I have another set of heads that appear to have been loved on a visited by Captain Airflow …41.5 intake and 39/40 exhaust depending on where you measure. (D shaped exhaust) Compression with current heads measures 12-5:1 need to verify with the big port heads still. In my quest for more power I am considering using these. -should probably leave well enough alone but… Anyway, any thoughts on using the big port heads? Quote:
Any competent machine shop familiar with Carrillo rods should be qualified to rebuild those rods. They may have to fabricate the pin bushings.
The pistons used in your build have the 12.5 compression ratio because they were designed to run in a completely different chamber configuration. RSR heads had a considerably different combustion chamber (much larger volume with different valve angles). That means, the valve pockets in the RSR piston do not match the valve angles in the 2.7 head. Is that OK? well, it's OK until you start measuring valve to piston clearance with any real accuracy. The 2.8 RSR was designed to run 10.4:1 and that number was always very optimistic. |
| All times are GMT -8. The time now is 04:38 AM. |
