Piston's & Cylinder's for '78 SC
Will the pistons/cylinders with part number 930-103-983-05 (for an 81-83) work in a '78 SC? Pet chart indicates up thru 1980, the part number should be 930-103-962-03 (or -04). Thanks...Steve
Yes, the later higher compression pistons (9.3 vs 8.5) with the early large ports is a nice combination.
john |
The biggest thing is, you have to use high test fuel.
Cams are the same but the settings are different Bruce |
Send me an email using the link below. |
| All times are GMT -8. The time now is 10:30 AM. |
