-   -   ITB Recommendations (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1184518-itb-recommendations.html)
rcguerena33 10-05-2025 11:28 AM
ITB Recommendations
Hi -
I’m nearly done freshening up my 9M 3.8 engine and need/want new ITB’s to replace the somewhat outdated 9M ITB’s. The engine specs, briefly are -
964 case
993 crankshaft
Carrillo rods
102 mm 993 Clubsport Pistons
102mm x 107mm slip fit cylinders
9M intake valves
9M exhaust valves
9M retainers/springs
9M Billet heads
9M Intake manifolds
9M Race cam
9M Headers
Motec M130
Coil on plug
Rev limiter is set at 7,800 RPMs and this setup was putting out north of 400 HP on 95 (we’ll be testing and tuning with the current setup in the coming months).
Any suggestions?
winders 10-05-2025 06:32 PM
The best are the AT Power ITBs...I would go with the 48mm size. That is what I had on my 3.8L race engine that produced 450 HP....
Nk993 10-06-2025 03:59 AM
was that your own testing or 9ms imaginary testing? (sorry I just have a very low opinion of them)
JoeMag 10-06-2025 09:36 AM
I also have AT Power's ...48mm, I like them. You note intake manifolds. Do you mean an actual intake or stacks? From a long time ago I recall 9M's heads had 42mm intake port, is that what yours are.
rcguerena33 10-06-2025 10:59 AM
@nk993 - the old dyno was 9m's.... No idea if it's close/accurate but just trying to get a ballpark out there for conversations sake. We'll run our own dyno and numbers in the coming weeks but honestly don't care about 400 vs 375 hp etc. I just want it setup to maximize what I have and hope we can have a fun conversations/debates about what it puts out!
@joeMag - just stacks (the language was from an old post so easy to copy and paste). I have 42 mm intake ports.
winders 10-06-2025 11:15 AM
I had Xtreme heads with 45mm ports....I would prefer the smaller ports with the 48mm ITBs for a street engine.
Regardless, the AT Power ITBs are the best but I not a fan of their drive by wire setup. I did my own with dual Bosch actuators in a custom setup from EFI Australia.
Henry Schmidt 10-07-2025 06:05 AM
"Best" is always an interesting claim.
There are a number of nice systems on the market that fulfill most normal use applications. Jenvey, Clewett, Rasant, PMO, Rothsport and even Supertec have systems that will meet most needs, sometimes at very reasonable prices
Henry Schmidt 10-07-2025 06:25 AM
Kinsler, in a partnership with Ed Pink (Singer), make a system that offers a progressive linkage that improves the driving experience. Well tested, sexy and made in America is always a great selling point.
http://forums.pelicanparts.com/uploa...1759843396.jpg
Henry Schmidt 10-07-2025 06:35 AM
Rasant on a 2.8 SS built by Supertec 20 years ago.
http://forums.pelicanparts.com/uploa...1759843894.JPG
Henry Schmidt 10-07-2025 06:41 AM
Let's not ignore the Heritage systems offered by Jenvey. A great way to maintain that "period correct" Porsche aesthetics. Throttle bodies that replicate Weber IDA carburetors. They fit stock early air filter housings.
http://forums.pelicanparts.com/uploa...1759844380.png
Henry Schmidt 10-07-2025 08:09 AM
Rothsport/Singer ITB fitted to a 3.8 engine for the street.
http://forums.pelicanparts.com/uploa...1759849256.jpg
Henry Schmidt 10-07-2025 08:32 AM
Supertec ITB. Jenvey throttles on a manifold we cast in a friends garage using old Mahle Volvo pistons. State of the art? hell no but it was a fun project.
http://forums.pelicanparts.com/uploa...1759850991.JPG
They can be sized for any 911 engine. Here they are fitted to a 340hp street car 3.9 engine.
http://forums.pelicanparts.com/uploa...1759850927.JPG
http://forums.pelicanparts.com/uploa...1759850789.JPG
JoeMag 10-07-2025 09:44 AM
Robert -- My reasoning for picking the AT powers was that they have a blade for the throttle plate and not a shaft with a throttle plate through it. The blade is ~1.5mm thick. Comparing area down the throttle of a 1.5mm blade and 6mm shaft, you'll see that you basically can go down a size of throttle and the air faces the have same area. 45mm w 1.5mm blade is equiv to 48mm with 6mm shaft. They also have cam'ed mechanism on their 993 actuator that gives progressive response. there's a bearing thats attached to the blue part that fits into a groove in the red part that provides the throttle motion.
If I recall correctly the Rasants have a port for idle air control port for don't touch the gas pedal warmups.
Henry -- Nice set of pics.
JoeMag 10-07-2025 09:51 AM
http://forums.pelicanparts.com/uploa...1759855874.jpg
stephen1070 10-07-2025 01:47 PM
simply the best ?
This is a cool set up for an owner wanting this airbox configuration - the best for me too!
Thank you!
https://www.youtube.com/watch?v=8Afffdv5Tfg&list=RD8Afffdv5Tfg&start_radio =1
Originally Posted by Henry Schmidt (Post 12543692)
Who are you again? My post is not about you. Get a life.
My post suggests that "best" is subjective. It always is. My post shows many different options based on many different criteria. Not everyone is about maximum performance, in fact most people playing with these old engines have different criteria base on things as simple as esthetics, cost or even manufacture.
I just built a high butterfly intake for a customer who whats to run the stock air filter housing on an ITB system. AT Power doesn't offer it so obviously AT Power is not "best" for him.
http://forums.pelicanparts.com/uploa...1759865322.JPG
AintGotNoGasInI 10-07-2025 08:43 PM
Topper performance tuning makes a pretty good ITB set up, pretty affordable as well. I'm installing them on my car currently. Dual DBW in my opinion is a massive benefit in ITB'S. for my purposes I wouldn't purchase ITB's without them
Tyler, the owner of the company is very helpful. I'm sure if you contacted him, he'd help you out
Turbo_pro 10-08-2025 09:37 AM
Back on topic after the silly trip down obsession lane: WTF is that?
Race Head has some pretty cool options. I saw a set on 3.8 engine in a transplant to an 87 Carrera. Carbon Rain hats are stellar.
https://racehead.com.au/product/porsche-964-993-itb-kit/
http://forums.pelicanparts.com/uploa...1759940596.jpg
Nk993 10-08-2025 10:42 AM
Theres also some guy in denmark producing barrel throttle ITBs... DRS developments installed them on their to replace the AT power ones, but havent seen any updates from them in a long time, so dont know if they tested it yet.
they mention it here: https://youtu.be/HvX98EC3SIM?si=8EyplpJjClxBbk4n&t=667
rcguerena33 10-08-2025 12:41 PM
ITB talk gets everyone fired up! Ha.
I'm really leaning towards the AT Power ITB's based on some of the above info and their overall adaptablity. Kinsler is a close second... with the M130 I'm running we can only do a single DBW motor setup. Last option is to convert the existing 9M to a DBW but I'd still be out of idle air control monitoring throught the ECU.
We'll see how testing looks next week and figure out next steps from there. Thanks all for the help and keep you posted.
Jeff Alton 10-08-2025 07:21 PM
We have used many over the years. Not going to say what is best... :)
For a traditional butterfly style, we like Jenvey. Used them countless times with great results every time. We have also used PMO, Clewett, TWM (borla now?) Hargett (did some testing for them and not even sure if they are around?) and RHD.
Our go to is the Jenvey, high quality, easy to adjust and maintain their adjustment. We adapt the throttle set up a little to our liking. On same engines, they made more power than the PMO's but the PMO looks like a weber.
Jenvey also offers their heritage line, which looks amazing if you want a carb look, as injectors are hidden. We have not tested those. The Clewetts are very functional, everything is well thought out mechanically, just aestetically, they are a little "cludgy".
Was not impressed with the RHD at all. Too many pieces involved (I get it, modular to fit many applications) the linkage seems a little "light" for the appplication and they had a complete lack of instructions/tips with the kit. Client really wanted them, so we got a set.... They perofrmed well, but just not quite what we were looking for.
Not tried the AT Power ones, may some day soon. The clients we have built motor for with the all of the listed ITB's have been thrilled with the performance, driveability and throttle response. So we are happy.
Your ECU choice and tuner choice are likely more important to get good performance and driveability.
Cheers
Henry Schmidt 10-09-2025 06:04 AM
Cheers
Great information! Thanks Jeff
ITB is not in our wheelhouse so your expert input based on actual experience is invaluable.
Henry Schmidt 10-09-2025 09:18 AM
One of the very first versions of Richard Clewett's ITBs on a 2.7 RS replica built by Supertec. Easy to use, great performance.
http://forums.pelicanparts.com/uploa...1760025227.jpg
http://forums.pelicanparts.com/uploa...1760025011.jpg
Rivet 10-09-2025 10:10 AM
Cheers
Just as a small update on the RHD ITB's. They have since made a small revision on the linkage and now include a full published instruction manual with tips.
Henry Schmidt 10-09-2025 01:42 PM
Some people might find this to be the "best"!
3.5 EFI using RSR high butterfly built by Ruff for Jerry Seinfeld.
http://forums.pelicanparts.com/uploa...1760036367.jpg
targa72e 10-09-2025 06:44 PM
You do not need Idle air control with DBW. You can use the ECU to open the throttle to get what ever Idle you want.
John
Turbo_pro 10-10-2025 06:02 AM
John
Your "last" option should be the first option. Whenever you have money invested in a "custom" build, trying to modify the parts you own is a great starting point.
My experience with EFI is so limited that I wouldn't begin to understand issues with the 9M system but if you can figure out what is missing, mitigating the issues by modifying what you own seems reasonable. Throwing money at a problem is rarely the "best" way to proceed.
General rule, not aimed at you John. I am agreeing with your suggestion.
Jeff Alton 10-10-2025 06:27 PM
Thank you for the info. I should have also noted, the owner/contact was always responsive and easy to deal with.
Cheers
Henry Schmidt 10-11-2025 05:42 AM
For anyone looking for a cost effective forey into the ITB world, I have a stellar set of 50mm PMO ITB for sale. These will fit any size 911 but probably should be used on a 3.0 and larger.
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1184687-quick-sale-stellar-set-pmo-50-mm-itbs.html
http://forums.pelicanparts.com/uploa...1760186508.JPG
These ITBs tend to give you project a more "period correct" aesthetics and still offer the modern convenience of programmable induction.
You can even use a factory early 811 air filter housing to maintain an even more authentic aesthetic.
http://forums.pelicanparts.com/uploa...1760187742.jpg
Henry Schmidt 10-11-2025 11:02 AM
Here's another exciting option I stumbled across in my research.
This system is remarkably similar to the fuel delivery system used on some the NPTI GTP cars of the late 80s / early 90s.
I only know this because I owned 11 of the GTP engines as well as one of the cars.
http://forums.pelicanparts.com/uploa...1760205746.jpg
JoeMag 10-11-2025 12:35 PM
Another consideration is length of intake...
Graph of harmonics for various intake lengths. Length is total length of intake; top of stack to back of intake valve.
A cut of dyno graphs with an intake manifold and straight velocity stacks, a reference stack length, then adding to it in approx 1" increments.
http://forums.pelicanparts.com/uploa...1760211240.jpg
http://forums.pelicanparts.com/uploa...1760211325.jpg
TimT 10-11-2025 01:14 PM
Years ago we built a 3.8 using dual staged injectors with Haltech EFI. The intake, ITBs, intercooler, headers were all sourced from MODE
The engine made impressive power..
I have other pictures ..... somewhere....
http://forums.pelicanparts.com/uploa...1760213681.jpg
http://forums.pelicanparts.com/uploa...1760213752.jpg
TimT 10-11-2025 01:20 PM
http://forums.pelicanparts.com/uploa...1230141767.jpg
Neil Harvey 10-12-2025 10:51 AM
This has been interesting to read. Some really good ideas and comments about what has been done in the past. All good info to take in. What has worked is really good to know.
Project 24 includes an new ITB system. Too early to say or show what it is. We have tested both Barrels and Butterfly types on the flow bench. The Barrels certainly show better flow and speed once opened fully but the Butterflies still beat out the Barrels at part throttle. Just turning the air twice I assume is the issue.
Our magnesium based 911 Project 24 is all about weight, engine speed and acceleration so air volume and speed are major factors. Anything not needed is removed, anything that can be made thinner and stronger is, the goal is to see how light we can make this engine. Cost is not the driver in this project, weight is. Hopefully some of these weight saving ideas can used by others in the future.
stephen1070 10-14-2025 11:22 AM
Henry - this car is on auction now and listed with a "3.4" - do you know the bore and the stroke that RUF used?
Also - what do you think of the exhaust on this car?
Thank you
http://forums.pelicanparts.com/uploa...1760466111.jpg
Henry Schmidt 10-14-2025 11:31 AM
Thank you
3.4 seems right. Ruff did use the 98mm short skirt Mahle pistons in many of their builds. Quite often the customers would complain of cold start piston slap.
Half of the exhaust looks great, the primary half uses a flat collector and I'm not a fan. With this engine, I would prefer to use a header system with shorter primaries.
Something more like these.
http://forums.pelicanparts.com/uploa...1760466651.jpg
