PCA Member since 1988
Can the oil tank sender seal be replaced in situ?
Or do I have to drain and drop the tank?
Yeah it’s leaking pretty badly. So I gotta do it, one way or the other.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-10-2025, 12:33 AM
proporsche's Avatar
i usually drain the tank .it does not take to long..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-10-2025, 12:59 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
No problem to change the sender seal with the tank in place. Of course, it must be drained and cleaned well before opening it up. I found the screws holding the sender down were loose, likely due to the gasket shrinking.
1986 Targa Guards Red
2021 MT09 SP
Old 09-10-2025, 03:53 AM
The oil tank sender seal can be replaced in situ, but it is a notoriously difficult, messy, and risky job.
It is not a simple "drain and replace" task and requires a significant amount of skill, patience, and the right tools.
Old 09-10-2025, 06:10 AM
proporsche's Avatar
petekz: very easy job not as anoth..saying
Just make sure you have the surface clean after you remove the sender .Also align the gasket to the sender prior inserting it into the tank .It goes in with a little twist float pointing down and after turn the sender to it final position..no brainer Also use only cork gasket not silicone, plus new washers ,nuts could be the old ...
Ivan
Old 09-10-2025, 11:37 AM
Guys, thanks for the advice. So I can replace the seal in place, but there is the risk of getting dirt into the tank, which goes directly to the oil pump amd bearings. One other “twist” to the job: My car is a 1973, which does not have flared fenders of 1978 and later, so it will be tighter working in there. I will look at removing the tank first. By removing it, I can also clean out any sediment collected in the bottom since 1973!
Old 09-10-2025, 04:13 PM
One other question. Was the original seal cork or rubber? Maybe just tightening it will work for awhile.
Old 09-10-2025, 05:14 PM
Get the rubber one and split it on top to pass around the bolts. Narrow body makes removal difficult. Put a dab of aircraft permatex on the split as you close the job.
Bruce
Old 09-10-2025, 05:57 PM
Great idea. Thanks.
Old 09-10-2025, 07:40 PM
proporsche's Avatar
Bruce
yes good idea with some permatex..i have always found the rubber way to thin that is why suggested the cork The rubber i used mostly on fuel level sending unit
thanx Bruce
ivan
Old 09-10-2025, 10:39 PM
I have replacement rubber gasket already. It's pretty thick. I didn't measure it, but close to 1/8". I got it with the fuel sender unit I ordered a couple years ago.
FYI: The fuel and oil sender gaskets are the same part number.
Old 09-11-2025, 12:21 AM
In light of the non flared fenders, I think you should be looking at removing the tank. On my 86, getting the sender in and out was on the tight side but doable. Without the extra room from the flares, I bet it would be difficult.
2021 MT09 SP
Old 09-11-2025, 04:29 AM
Temporary success: the nuts on the sender were loose enough that I could remove a couple of them with my fingers. I decided to just try tightening them. No oil drips driving it around today. I will replace the seal eventually. I plan to drop the engine and trans this winter anyway, and will have to drain the oil and disconnect the hoses as part of that process. That will be the best time to do it.
Old 09-11-2025, 05:55 PM
Follow up: Well, tightening the nuts reduced the leak, but did not eliminate it, so I finally got around to replacing the seal. The original was cork and was hard and cracked. I used the rubber replacement part that is also used on the gas tank sender, and the sender flange appears to be totally dry now.
I was able to clean off the side of the tank and inside of the fender with a pressure washer, then a toothbrush and solvent, to get most of the dirt off the area around the sender. Although my car is a 1973, the narrower rear fender did not interfere with removing it. It was a bit of a PITA to get out, and required some rotating and tilting and playing with it until it came out. After removing it, I stuffed a rag in the hole on the tank to keep dirt from getting in there. Then I cleaned around it some more and carefully scraped off the cork seal still adhered to the tank. Then I reassembled it with the rubber seal.
Bottom line, it's not a bad job, but a bit of a PITA the first time you do it. After having done it once, I could probably do it again in half the time. The job took me 1.5 hours, not counting the pressure washing at the beginning.
Old 10-16-2025, 01:31 AM
This might too late for PeteKz but one should be careful about using a pressure washer on any leaking component. If fluid is leaking out, the pressure washer will probably force water into that component! You're probably OK with something that is only weeping, but I would avoid spraying directly at the leak. A few drops of water will eventually be evaporated by the hot oil and taken away by the crankcase ventilation system. The other thing to be mindful of is any compartment vents like on the top a transmission.
Old 10-23-2025, 07:44 AM
Yup, too late for me, but good point about not pointing the high pressure spray directly at the leaking seal. If any water got in there, it has certainly evaporated out by now.
Old 10-24-2025, 11:08 PM
I’m replacing both the oil tank sender and fuel tank sender seals, as both are removed from the car right now for sheet metal repairs.
I received cork gaskets…. The ones I removed were rubber. What is the issue with using cork instead? I certainly don’t want to be doing this again anytime soon!
Dave
Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina"
PCA Member- Sacramento Valley region
Old 10-28-2025, 05:09 PM
I think that depends on how old you are!
The OE cork ones last a long time. The one that hardened and cracked and leaked on my car probably was original. If not original, it was at least 32 years old, 'cause that's how long I've owned my car. If you're in your 60's or later, the cork probably will outlast you. If younger, you might want to order the rubber one. Since my son will want to keep my car, I used the rubber gasket.
Old 10-29-2025, 12:03 AM
I get to have a cork gasket…cool
Dave
Old 11-16-2025, 06:11 PM
safe's Avatar
I replaced my gasket (with cork) 19-20 years ago, did it in situ on a non flared 77. It was a bit tricky maneuvering the float out of there.
It now leaks again, and the sender don't work....
Magnus
Old 11-17-2025, 01:54 AM
Tags
oil tank seal
