Another engine issue
Hi everyone,
I have a Porsche 911 with a freshly built 2.7 engine. Specs: 2.7L engine, 9.8:1 compression ratio 2.4S original cams Ø90mm Mahle pistons Intake valve: Ø47mm Exhaust valve: Ø40mm Intake port: Ø37mm Exhaust port: Ø35mm Intake valve lift: 10.5mm MFI system (no solenoid/cold start) Cold iridium spark plugs Fully rebuilt from scratch — 0 hours on it The engine started fine for the first time. Oil pressure isn’t perfect, but I’m getting around 1.5 bar at idle and 5.5 bar under load when warm, which seems acceptable.I think it's importante to mention that the engine was rebuilt in 2019, and was sitted in a dry place for 6 years until now Now the issue: When accelerating (around 2000 rpm and above), I can hear a tickling noise coming from the left bank. There’s also a bit of bluish smoke from that side, but not too much. I checked: Compression: all six cylinders are OK Valve clearances (left side only intake): 0.1 mm Spark plugs: all dry except cylinder #3, which shows a bit of oil Also check with camera and cylinder looked OK as far as I could see Any ideas what could be causing this? What would you check next? Thanks in advance for any insight! |
Anyone can support me?
Any idea? |
Post a video with the noise.
Possibly the valve is sticking slightly open on that cylinder, creating the clicking, but eventually closes by the time of inspection.
You may be dealing with a valve to piston clearance issue.
The Mahle valve pockets are designed with a pretty close perimeter tolerance. The stock intake valve is 46 mm mm and you state that your intake valve is 47mm. I may be experiencing a slight interference on just one or two valves. Quote:
I did insert a boroscope and no damage is seen from inside the chamber
Videos for sound and reference https://youtu.be/Kpym3LuPdZg?si=xHQQHLHfKI8yg2Cy https://youtu.be/iCW2t6KjsfE?si=zrvkGVuOCsAoC8UQ |
Sounds to me like valve noise from a loose valve or two, so recheck the valve clearances and be sure to make the adjustment at TDC on each cylinder. Yes, there is a procedure for adjusting multiple valves at certain points, but do it by the TDC method to be sure.
Next, it also sounds like it could be loose or blown exhaust gaskets. Check those. While you have the valve covers off, check for broken head studs. |
I will check those, but the #3 cylinder spark plug oily (not much) has nothing to do with valve clearance I believe. Blown exhaust gasket can lead to this?
You mention compression good. You did a compression test? Did you did a leakdown test? Oily sparkplug could suggest some blowby. Could be unrelated to the oil pressure and valve train noise issues.
Did a compression test, and when cold around 12bar every cylinder.. Believe its satisfatory
Tried to blow air inside the #3, but don't have proper tools to do it. Couldn't ear air leaving from oil tank (don't know if there is any other way to do it) |
engine noise
If the valve is interfering with the valve pocket you may be able to feel it by checking valve clearance at overlap. Set each cylinder at overlap TDC, then gently screw in the valve adjusters until they bottom or scrape. Count the turns, each turn = 1mm. If you feel something like scraping or increased resistance, that's probably what's happening. If you don't feel anything odd, and the adjuster screws in freely 1mm or more, then it's unlikely that the valve is touching the piston.
Do this before removing the heads and post your findings. |
Can maybe this tickling connect to valve guides?
As I found an oily spark pluc on cylinder #3, maybe it's something out of tolerance |
| All times are GMT -8. The time now is 06:14 AM. |
