-   -   3.4 idle question... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1185068-3-4-idle-question.html)
PeteKz 11-06-2025 08:42 PM
Silverlock: Remind me, do you have an AFR gauge installed? If so, what does it read at idle and other conditions/.
silverlock 11-07-2025 10:46 AM
I don’t (b/c I didn’t know where I wanted to place it!) but have the sensor & harness installed.
I’m teeing up a fresh dyno run + AFR logging before end of season so I can have Steve Wong a) bring my redline up to 7.5k and b) see if there’s any “safe” power left on the table with the ignition map. Will post that + the logs when I get them.
Mr. Merk 11-10-2025 07:59 AM
Originally Posted by silverlock (Post 12559359)
Two videos:
- most recent, short & lumpy: https://share.icloud.com/photos/0a7vH5yEqTZ2fN5IGhOmBdTzw
- right after the build was done in May + about to drive it back to NYC: https://share.icloud.com/photos/087w8Q70esfEaKPw2G0FN_7fw
Both expire Dec 6th.
Driveability with the cams & lightweight FW has been very very good.
Sounds great!
