Intake Manifold Nut Install
I started to install the nuts to secure our intake manifold to the heads. The nuts got tight pretty quick, before they were completely engaged on the stud. I backed off for fear of loosening a stud from the head. I measure the studs at about 22.5 exposed length. The parts catalog lists 25. Even then, it seems the stacked items (not including height of 2 paper gaskets) should allow full engagement.
Questions:
Notes:
Hi
1/ At the cylinder head stud it looks like you have a deformed head lock nut, this is not what the factory originally fitted. I recommend not using these nuts. The original factory nut, 999 084 601 02 had a different locking mechanism and was 12mm across the flats. I recommend using these nuts. See more here: https://forums.pelicanparts.com/911-engine-rebuilding-forum/603688-intake-manifold-nuts-nla-now-what.html 2/ No comment. 3/ You may have to use calibrated hand to torque or crows foot adaptor or thin socket. Hope this helps. Cheers PS Parts Katalog here: https://assets-v2.porsche.com/nz/-/media/Project/PCOM/SharedSite/PorscheClassic/Original-Parts-Catalogue/PDF-EN-WW/KAT070_E_914_76_KATALOG |
2/ Single gasket would buy a bit of room. I used two since that's what the parts catalog indicated and came in the gasket kit. |
Get rid of those prevailing torque lock nuts...
I don't know why all of a sudden people feel the need to use them, another poster used them on the chain boxes and effed up the threads on some fasteners.. These particular nuts work by damaging the threads.....Also you have to adjust the torque values when using them...i.e. if it takes 4 ft/lbs to just rotate the nut, you have to add 4# to the spec value Toss those nuts in a round file.. Use plain nuts and wave washers. |
Regular nuts and spring washer are what's specified for the carb to the manifold. |
Those nuts work by distorting the threads..
Top stud not to bad.. bottom stud trashed.. http://forums.pelicanparts.com/uploa...1761056321.jpg |
I put my headers on with Nylok nuts like 5 years ago, and they looked fine when removed for this rebuild earlier this summer. The ones on before than (from around 2001) were also Nyloks. One inner one wandered off over the years, but no leaks. Dug up an old photo from 2013! http://forums.pelicanparts.com/uploa...1761339875.jpg |
The 12 mm flats on 8mm use JIS NUTS FOR 8 mm. You can get them through the heat boxes too instead of cap nuts. 1/4 inch drive 12 mm socket. Snap on 12mm works others may need grinding.
On the intakes, the factory used split 12 mm, not the brass exhaust but steel 12mm. Bruce |
Hi
"1/ The nut you see in the photo is 999-084-601-0C, ordered from Delaware Porsche who indicates this supersedes 999-084-601-02. It is a non-nyloc 12mm ATF locking nut. My understanding is the deformation is what makes it lock." Unfortunately supersessions recommended by Porsche don't always work that well in some situations. You need the aluminum washers on the magnesium manifold because the "as cast" upper surface of the manifold is not always perpendicular to the stud. The aluminum washers take up any misalignment as they crush. Good advice from Tim T: "Get rid of those prevailing torque lock nuts..." Cheers |
http://forums.pelicanparts.com/uploa...1763731475.jpg |
For intake flange applications we always use flanged/prevailing torque Jet nuts. 8mm thread with a 10mm wrench gives unparalleled socket access. Most professional mechanics understand that thread lube is used for proper installation. http://forums.pelicanparts.com/uploa...1763732197.jpghttp://forums.pelicanparts.com/uploa...1763739002.JPG http://forums.pelicanparts.com/uploa...1763739002.JPG |
Given the choice of base spacer and gaskets it really looks like new/longer studs are required. |
Obviously, I'm not a professional. ;) |
901-108-131-00: Intermediate Flange Gasket - Intake manifold 901-108-391-04: Gasket - Intake manifold I am still curious if different manifolds have different base thickness. |
Bell Metric has nuts and studs. studs) https://belmetric.com/m8-even-thread-stud-class-8-8-steel/?sku=S8X38EYLW nuts) https://belmetric.com/conical-lock-flange-nut-smooth-class-10-steel-din-6927/? simply a preference. nuts) https://belmetric.com/conical-lock-flange-nut-smooth-class-10-steel-10mm-wrench-special/?sku=NTLH8X10YLW |
Someone had posted earlier concern about the distorted shape lock nuts (not nylock) chewing up the stud threads. I take it you have not seen that. |
Whenever you work with a nut that uses a steel on steel mechanical locking system (prevailing torque), thread lube is always recommended. We make our own in house. It adds an extra step but provides the best results http://forums.pelicanparts.com/uploa...1763751603.JPG . |
Also I imagine in the F1 world, the prevailing torque nuts were installed following correct procedures.... i.e. determining the prevailing torque, adding that to the design torque, resulting in the correct design tension in the fastener.. Those top locking nuts are great if you're wanting to distort the threads on a stud.. Jet nuts... the nut deforms... not ruining a stud... http://forums.pelicanparts.com/uploa...1763770752.jpg |
We build every die cast aluminum case using the factory nuts you disparage so vehemently. http://forums.pelicanparts.com/uploa...1763829917.JPG |
| All times are GMT -8. The time now is 10:28 AM. |
