Engine
Can anyone decipher this early engine? This is a replacement rebuilt engine we bought back in 2003. I’m finally getting it going, should be a 2.0L, number looks ground? Can’t see type number? No stars, what is going on?
I believe this is a mag case due to which face its on, but looking for direction. I vaguely think this was a 914-6 engine per my bad memory. Running this in my 66 until I rebuild the original 907388 engine.https://uploads.tapatalk-cdn.com/202...30e8c05d1c.jpghttps://uploads.tapatalk-cdn.com/202...ca4584147e.jpg |
It's impossible to decipher the engine make based on those numbers. They certainly are not factory stamped. They might be the ugliest re-stamp I've ever seen.
The 914/6 had it engine number stamped on the top of the case adjacent to the oil thermostat. If there is a number up there it might be an original six. From what you have presented, it still a mystery. 914/6 engine number location. http://forums.pelicanparts.com/uploa...1762141124.jpg |
thank you! Found it.https://uploads.tapatalk-cdn.com/202...f286fb8c2c.jpg
| All times are GMT -8. The time now is 09:03 AM. |
