-   -   different 225mm fan housing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1186153-different-225mm-fan-housing.html)
tcrad32 11-13-2025 12:43 PM
anyone have any idea what this housing was for? the one on the left is from my 79, the one on the right i intended on using as a replacement,but has a smaller diameter where the shroud meets, and at rear of the band. both have same casting numbershttp://forums.pelicanparts.com/uploa...1763066469.jpg
djpateman 11-13-2025 12:49 PM
Possibly the one on the right was machined down to a smaller diameter. Not much you can do in that case.
tcrad32 11-13-2025 01:39 PM
hey dj , ur probably right. however they did a great job at ruining it. not the answer i wanted but im finding out that buying anything from private parties online has that potential. i guess the search continues or i ll have to get 245mm . thnx for response
Henry Schmidt 11-13-2025 05:07 PM
What you are looking at is an attempt to replicate the 906 fan housing.
The 906 used a unique fan housing, strap, 225mm fan and a special small fan shroud.
Reproductions are available from CarPoint DE.
http://forums.pelicanparts.com/uploa...1763082268.jpg
Henry Schmidt 11-13-2025 05:10 PM
I'll take it....All you need is a smaller strap, 225mm fan (which you can made out of any 245mm fan) and the 906 shroud w/side block offs.
tcrad32 11-14-2025 07:13 AM
so are u telling me the 906 shroud has the same outer profile as this. suppose i need to find a pic of a 906 shroud. it doesnt look to be machined , everything is same texture. thx for response hs
Henry Schmidt 11-14-2025 09:46 AM
Who knows? I'm don't have the housing in front of me. What I'm saying is, there was a 906 fan housing that was smaller in diameter than the conventional fan housing.
As for "being machined", I guarantee it is a stock housing that has been machined to a smaller diameter.
http://forums.pelicanparts.com/uploa...1763142353.JPG
tcrad32 11-14-2025 10:53 AM
930- housing pics
http://forums.pelicanparts.com/uploa...1763146102.jpg
the front dia is 260 mm, 225mm fan upper left blade looks repaired
tcrad32 11-14-2025 11:01 AM
must be a limit on pics, not all here
tcrad32 11-14-2025 11:02 AM
http://forums.pelicanparts.com/uploa...1763146892.jpg
9 oclock blade repaired
tcrad32 11-14-2025 03:45 PM
hey henry if u have use for it i can part w it. but i still need a orig housing.
