-   -   Check valve (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1186290-check-valve.html)
bethkeen 11-17-2025 01:05 PM
Check valve
Should a '76 911 2.7 have a fuel check valve at the fuel pump outlet? Thanks!
Flat6pac 11-17-2025 01:36 PM
I recall, the 76 has the pump in the left rear. The banjo that connects there is the check valve.
911 356 066 04 is the hose, the check valve is in the banjo next to the pump
I have purchased the check valve by it self
Bruce
PeteKz 11-17-2025 01:48 PM
Same as above. Some pumps have a check valve on them, others use a separate check valve. Whichever, you should have a check valve somewhere between the pump and your CIS.
bethkeen 11-17-2025 02:02 PM
Bruce
yes, there are some in the banjo fitting depending on the year
bethkeen 11-17-2025 02:04 PM
chart notes pumps with the internal check valve with a (F) under outlet connectionhttps://uploads.tapatalk-cdn.com/202...7610b7a00a.jpg
