Oil Pressure Switch @ triangle, just want to confirm
Since I'm finishing up my first Porsche engine rebuild, I'm driving myself a little crazy wondering if I had forgotten anything.
I circled the parts I had a question about below. http://forums.pelicanparts.com/uploa...1765848200.jpg When I took it apart, I don't remember a check ball or anything like the photo. It was just the oil pressure switch, the mount (like #42) and a crush washer under it. Am I correct to think that? Is the small assembly with the check ball for a different model? There is a long passage under the oil pressure switch which leads straight down to the oil pressure relief valve. http://forums.pelicanparts.com/uploa...1765848200.jpg |
Your parts diagram shows parts that are on a 930 Turbo, not a NA car. Your pic looks correct.
Cheers |
Keep up the good work! Cheers |
| All times are GMT -8. The time now is 02:01 PM. |
