-   -   High Temp Wire Loom or Shrink Wrap - Engine Wiring Harness (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1187329-high-temp-wire-loom-shrink-wrap-engine-wiring-harness.html)
beniloa 12-18-2025 08:23 AM
Any recommendations for a short length of high temp split wire loom?
Heat resistant tape?
Maybe just use 1.5" (3 to 1) heat shrink over the cracked area?
http://forums.pelicanparts.com/uploa...1766074949.JPG
Thanks again you guys.
dannobee 12-19-2025 07:55 AM
Raychem DR-25 is the motorsport standard. If you want the type with internal glue, Raychem SCL.
Personally, I'd slip the piece over it and install the harness before hitting it with the heat gun, for a more professional finish.
