European Pistons and Cylinders
Hi Wayne,
Will be picking up your new book this wekend, but have a few questions in anticipation of reading it cover to cover. My car is a 1983 911SC with 76,000 miles:
1. When I'm ready to do a rebuild (needs valve guides and piston rings), are there any advantages or disadvantages to putting in new European pistons and cyclinders instead of re-using my old P&C (assuming they are okay)?
2. When we start to take it apart, how can I tell where it has been leaking (the entire underside is wet, but it's not from the oil return tubes or the valve covers; the seepage seems to be from above, where I can't see when it's on the lift).
3. Are there any modifications that you recommend, other than Carerra chain tensioners update and Carerra oil cooler?
Thanks for your help...............Andras
Old 10-02-2003, 01:26 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
How do you know that you need new rings and guides? Most of these engines go way past 200k miles without a rebuild. I tore mine apart at 141k and only because i broke 4 exhaust studs and wanted to learn how the motor worked.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 10-03-2003, 11:48 AM
