-   -   964 motor rebuild tools? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/120918-964-motor-rebuild-tools.html)
ChrisBennet 07-28-2003 10:26 AM
I'm starting to look for 964 rebuild tools and I was wondering if the tensioner tool (9401) is necessary or one of those tools nobody bothers with.
thanks,
Chris
Tyson Schmidt 07-29-2003 12:51 AM
Once you take it apart, it will be pretty obvious how to make your own tool for this. Just take a square piece of metal, drill two holes at opposite corners that are the same dimension as th tensioner housing, then drill and tap a center hole for a bolt to tension the rail.
ChrisBennet 07-29-2003 01:18 AM
Thanks Tyson. Now go to bed!
-Chris
